I have a Raspberry Pi 4b connected via ethernet with Wifi disabled but every few seconds I am getting a popup that says “authentication required, system policy prevents Wi-Fi scans”. Why would the system be trying to do a Wifi scan when Wifi shouldn’t even be running?
I am trying to reproduce this but I am unable to so far. May I ask which version of Ubuntu Budgie you are using? (22.04, 22.10?) Also, is the popup happening on the local machine, or is it happening on a remote machine when you connect via RDP? I assume you have RDP enabled on this Pi, and if so, was in enabled via the Budgie Pi Configuration App, or through Budgie Control Center?
