I just restarted my PC, and now it keeps me at the dots screen/tty in some cases
press esc - that should flip to the text boot - where is it stopping at?
It just kicks me out to the TTY
had you installed or removed any software before restarting your PC?
If so what?
I don’t remember doing so.
see if it’s a kernel issue - press shift when booting to display GRUB and boot with an older kernel
Tried that to no avail.
edit your grub boot and remove “quiet splash” - this should boot but in text mode. What does it stop on?
Ubuntu 17.10 Nitro Username or something like that.
This. Is very difficult to diagnose without more info about your machine. E.g. are you using any proprietary graphics drivers? What kernel are you using?
