Just arrivet at Ubuntu Budgie from Windows. It seems pretty good. But I can’t drag&drop. Nothing. Neither files nor folders. Is this normal? or it’s a bug o simply a bad configuration I’ve made?
Drag & drop should work just like on any DE. Could you give an example?
I apologise for what I said. Of course it works, it was my fault. Thanks anyway!
No problem
Glad it works.
