Failed to start detect the available GPUs and deal with any system changes
Failed to start Light Display Manager.
I am getting this error whenever i boot up my PC, after 2 or 3 attempts it gets resolved.
I went to the internet and searched
I found one solution
https://bbs.minisforum.com/threads/on-reboot-only-failed-to-start-detect-the-available-gpus-and-deal-with-any-system-changes.1792/
Thanks for your reply. I solved it like this:sudo nano /etc/default/grub
change: GRUB_CMDLINE_LINUX=“” to: GRUB_CMDLINE_LINUX=“nogpumanager”, save and exit: CTRL+O, CTRL+X
update grub: sudo update-grubBut I am not sure if that is the desired solution. I will definitely try your fix today and report back.
the above solution didnt worked, so i am trying the second solution
This is a known issue with lightdm and gnome. I see it have latest intel gpu.
Let me find the fix for you.
Can you this fix.
Edit this file /etc/lightdm/lightdm.confAnd add this line under [LightDM]
logind-check-graphical=true
the issue is i dont see lightdm.conf file in the above directory, Has anyone encountered this issue before.
