Failed to start Light Display Manage & Failed to detect the available gpus and deal with any system changes
Hi
I’m new to linux and ubuntu, budgie is my first.
I’ve been running it for a month for work and really enjoying it.
Today, I installed lutris and wine so I could play some Celeste.
Worth mentioning is that I have intel Xe gpu but I ran the these commands meant for nvidia by mistake:
sudo add-apt-repository ppa:graphics-drivers/ppa && sudo dpkg --add-architecture i386 && sudo apt update && sudo apt install -y nvidia-driver-515 libvulkan1 libvulkan1:i386
I realized my mistake when it was all done so I removed the packages and ran the intel commands
sudo add-apt-repository ppa:kisak/kisak-mesa && sudo dpkg --add-architecture i386 && sudo apt update && sudo apt upgrade && sudo apt install libgl1-mesa-dri:i386 mesa-vulkan-drivers mesa-vulkan-drivers:i386
And then I rebooted the system as asked
The commands are taken from an official guide here: docs/InstallingDrivers.md at master · lutris/docs · GitHub
That’s when the newbie panic hit me because I got the two errors mentioned in the title and then thrown to the console.
I did some research and tried some solutions
I wasn’t able to get the lightdm service to start
I tried
sudo dpkg-reconfigure lightdm but it doesn’t output or change anything.
I tried reinstalling any package that had lightdm in the name with nothing.
I did some more research and found that budgie uses slick-greeter so I tried reinstalling and reconfiguring it, nothing from that either.
I really hope I can fix this without rinstalling the system, there is so much to lose in the system drive and uncomitted changes that I now regret =")
I would appreciated any help possible.
hmm - kind of depends what else you have tried to fix.
At a minimum purge those PPAs to get to a stable state i.e.
sudo ppa-purge ppa:kisak/kisak-mesa
sudo ppa-purge ppa:graphics-drivers/ppa
Thanks for the reply
I purged the PPAs with success and rebooted but the errors remain.
I did some more research and ran these hjncommands
dpkg --print-architecture
Which outputs amd64
And
dpkg --print-foreign-architectures
Which outputs i386
Is the issue here maybe?
How do I know which one is used, I have a 64-bit system
And the command
sudo service --status-all | grep lightdm
Outputs:
[ - ] lightdm
in theory those will not have impacted anything - those commands just allows 32bit packages to be installed from the PPAs. lightdm and slick-greeter don’t use 32 bit packages.
hmm.
Do check if you have any remanent of the nvidia drivers installed
sudo apt purge nvidia [press tab a couple of times to complete]
If any packages are returned you have those packages still installed - you can safely purge those
I purged all packages that contain the string nvidia
There were some starting with nvidia and some with libnvidia. All of them removed.
I tried rebooting and reinstalling all packages with the string lightdm or slick in it and reconfiguring the services but nothing
I appreciate your help
you are kind of at a detective stage looking at logs etc
journalctl -ae --full
Scrollback using the arrow keys to see log entries around lightdm - maybe there are messages describing what the issue is.
If you have to reinstall then you could backup the important stuff from your home folder via booting from a live-session and copying what you need to a USB drive.
The journalctl full command has lots of output that is difficult me do understand, on the other hand:
journalctl -xeu lightdm
Outputs this:
'Fraid not a lot to go on from that screenshot :frowning:
Yep :sweat_smile:
I guess I will be reinstalling budgie tomorrow morning.
Thanks for your help!
