I prefer a vertical panel and being able to run my cursor along the left side of the screen to select items. But upon hovering along the left screen edge, item selection is glitchy and flickers between registering and not registering the mouse hover. This seems to apply to all types of panel items.
Hmm, it does happen with Plata and every other theme I’ve tested. The problem seems to be confined to a left and top panel orientation, though. Right and bottom panel orientation is fine. I can’t seem to figure out how to get 2560 width working full screen on a virtual Solus install, so I can’t quite test it out properly there.
But I’ll keep other updates upstream. Thanks for the help.
The issue persists on various 16:9 resolutions, with and without scaling/fractional scaling. Just to be clear, I’m having the top/left panel issue on a non-virtualized Ubuntu Budgie install. I’ve then failed to replicate at least the top panel issue on a virtualized Solus install. It’s possible that the issue occurs on at least virtual Solus with a left panel orientation, but I can’t get proper full screen resolution (2560 width) on my virtual Solus install to test that out.
I don’t have a usb stick handy, but I’ll try it out from a Solus live boot when I first get the chance. Thanks.
