Installing Window Shuffler on Fedora 34
Need help
I’m using fedora 34
I installed shuffler using:
meson --buildtype plain -Dbuild-all=false -Dbuild-window-shuffler=true --prefix=/usr --libdir=/usr/lib
(all dependencies are satisfied)
And rest of the installation process are completed successfully.
And even I can open the window shuffler control box and the shuffler is enabled
But none of the shortcuts work.
Do I need to do any extra steps in installation?
…To locate wher the issue could be: is shuffler here on your system: /usr/lib/budgie-window-shuffler? If so, could you run /usr/lib/budgie-window-shuffler/tile_active 0 0 1 2? it should move the active window to top_half
You will need to also build the budgie-extras-daemon for the shortcuts to work
meson --buildtype plain -Dbuild-all=false -Dbuild-window-shuffler=true -Dbuild-extrasdaemon --prefix=/usr --libdir=/usr/lib
Yes the tile_active is working.
now installed budgie-extras-daemon with the option true
But still the shortcut is not
Should I check for anything else?
Do logout and login - on login check that the budgie-extras daemon process is running.
I think the extras daemon is not running
[vrag@fedora ~]$ sudo ps aux | grep budgie
vrag 8130 0.1 0.6 636348 25100 tty3 Sl+ 16:59 0:00 /usr/lib/budgie-window-shuffler/windowshufflerdaemon
vrag 8142 0.1 0.6 562264 23812 tty3 Sl+ 16:59 0:00 /usr/lib/budgie-window-shuffler/layouts_popup
vrag 8153 0.1 0.5 562220 23588 tty3 Sl+ 16:59 0:00 /usr/lib/budgie-window-shuffler/gridwindow
vrag 9571 0.0 0.0 221528 836 pts/0 S+ 17:06 0:00 grep --color=auto budgie
How to make it run?
found invoke.py in /usr/lib/budgie-extras-daemon should I run this manually, if the what arg must be passed
odd - it will install a budgie-extras-daemon.desktop to your /etc/xdg/autostart folder. Unless fedora does stuff differently - that should be enough to make the daemon run on login.
in fedora the budgie-extras-daemon.desktop is in /etc/xdg/autostart/
after starting it manually the shortcuts work prefectly
Think I need to add an autostart rule to extras-daemon manually in fedora
Thank you so much for the help :v:
The grid shade is not getting adjusted !
Should any extra dependency be installed ?
Could be theme related. Try different themes like Pocillo or Arc theme.
