Nemo Theme PROBLEM
I have a fresh install of Ubuntu Budgie 20.04.1, and I found an issue with the default theme. Allow me to demonstrate:
  1. Open the default file browser (Nemo 4.4.2) and select a folder.
  2. Right-click and select Rename.
  3. Here’s the problem. The theme does not highlight the name of the folder we are renaming, or it may be white, but either way, it is a problem.
Yes, yes, yes. It does have a box around it, but it NEEDS a highlight too.
Thank you for reading!
Sounds reasonable.
If you or anyone else can resolve that would be most welcome.
The github repo for pull requests is here https://github.com/ubuntubudgie/pocillo-gtk-theme
I don’t know if someone has fixed it yet, but I’ll try to make pull request with the fix.
