So after I installed 19.04 I have been getting 2 desktops. I had the Active Desktop installed before from the “Help test “Active Desktop” for 19.04” thread that I forgot to uninstall. Any help on how I can fix it?
Thanks.
Preview: https://imgur.com/a/0dnjSb3
ok - the image didnt show anything.
I assume you are referring to both “Active Desktop” aka “DesktopFolder” and nemo-desktop running?
If you dont want nemo-desktop running, have a quick look at this thread - Hide Desktop Icons in 19.04
hmm whats the difference between the two? I cant seem to be able to interact with the nemo desktop. I disabled it now. The preview should work it works for me.
Nemo-Desktop plays the role of desktop icon handling that nautilus 3.26 used to-do.
You cannot have both nemo-desktop and DesktopFolder running at the same time - so yes, you cannot interact with the nemo-desktop until you stop DesktopFolder from running on logon.
nemo-desktop is meant to be a stop-gap until 19.10 when DesktopFolder will replace it. But - big but - if DesktopFolder isn’t up-to the quality and expectations for 19.10 then nemo-desktop will be the default desktop icon handler for 19.10 & 20.04 LTS.
