Hi all,
I’ve read that in next J*** J*** subiquity will become a standard so I’ve decided to give it a try by downloading 21.10 canary that mounts subiquity as default installer.
Well, I hope that someone will work hard on it before releasing next LTS because or it’s buggy or (maybe) is myself the one who need to understand it
(and, if this is the case, can someone explain me how to do?)
Trying to explain, if I go directly telling subiquity to use entire disk, there’s no problem but if I choose “other” … ehm … is simply impossible to create/manage partitions, the only way to do it is creating them before via GParted (or parted, as you prefer) and even in this case, “next” button doesn’t work anyway, it stays gray and it isn’t possible to click it.
Has someone given a try to subiquity in GUI version? I’ve read that in cli version is the same, anyway, so I hope that before launching 22.04 “pre-alpha”, Budgie developers (or Canonical developers or anyone else) will solve that problem.
Thanks and best,
Sil
