That is likely to be an upstream issue … please raise on its tracker
@fossfreedom , flatpak and snap builds does not show tray icon? Could you suggest what could be the problem? Something with sandboxing ? It used to work before electron version upgrade. After the update with support for only KStatusNotifierItem, no tray icons for sandboxed apps.
