Wifi suddenly disconnect
I hadn’t been using this slim laptop for a while, i turned it on and updated once budgie 10-14 days ago (just updated and turn off after few mins) .
when I tried to get some work done on it this afternoon, i received a 3.x MB update, then wifi started disconnecting within 10-15 mins. I have to reboot in order to get wifi back.
This laptop is using an intel AC 3165 wireless adaptor, i had exactly the SAME issue with windows 10 update last year, it’s driver’s problem. I had never encountered this issue in 19.04 budgie before.
What can I do? I don’t want to spend time re-installing everything again.
I am using win 10 to type this message now, no disconnection at all.
please kindly advice.
thank you very much.
What was updated?
If it was a kernel update then boot with the older kernel via grub (press shift immediately after the computer starts or press Escape)
I have no idea whether or not kernal has been updated or not… usually i just press update…
it was running on 5.0.0.15, now trying older kernal 5.0.0.13, it seems working fine now…
thanks a lot
I i thought it works but wifi disconnected again,have to reboot to get wifi back.
it worked perfectly before, I haven’t install any new software recently, i don’t know what causes this issue.
Please file a bug report:
ubuntu-bug linux
Additionally - you should be able to restart your wifi without rebooting:
sudo systemctl restart NetworkManager
(https://askubuntu.com/questions/271387/how-to-restart-wifi-connection)
no, i’ve tried this command, it doesn’t work!
nothing shows up in wifi/visible network, gotta reboot in order to restart wifi adaptor.
This is the typical symptom of that driver issue. I have no idea when the driver has been modified or updated… I received one budgie update today but i doubt it causes this issue.
was it because I updated once or twice via synaptic package manager? maybe I should only use the built in manager for future update.
Doubtful it has anything to-do with synaptic vs update-manager.
I am intrigued that this happened with Windows as well as linux. Two different operating systems.
It could also indicate a failing hardware component as well.
In the linux world - wifi drivers are typically part of the linux kernel - unless it hasnt been merged in the kernel it is generally available as a dkms module.
Yours is an intel and should be part of the kernel. Given that you tried a slightly earlier kernel and it still occurs would indicate more hardware than software.
I would test out an 18.04.2 live ISO - boot into the live session and leave it running for a while. If it doesn’t disconnect - then it points to a software issue with the kernel (typically) - or possibly a Network Manager issue. 18.04 uses kernel 4.18 and an older network manager. If it disconnects, then would strongly suspect a hardware issue.
Note - it could be a hardware issue with your wifi router as well where the computer is not restablishing a disconnection.
it’s perfectly fine in Windows 10 now, there is something wrong with 2018 Oct update, all I have to do was let windows choose the best driver automatically and it’s fine now!
I have no idea why i happened to my budgie this afternoon, it happened again 2 hours ago。 worse case I reinstall everything. It was working perfectly fine before.
thank you for your help
Maybe if you update to the latest kernel (5.1.15 I guess) the problem will be solved. But I am no sure if this is reocommended
I reinstalling budgie now. It keeps all previously installed apps and clear the system at the same time, hopefully the problem can be resolved.
hardware wise, i think the wifi adaptor is working fine because I have been using it for couple of hours in win 10 and I have had no problem at all.
thank you for your advise, i will give 5.1.15 kernal a shot before I erase EVERYTHING, this is the last option…
Yeah, because the lastest kernel has some upgrades at hardware compatibility. So, maybe it can work for you!
For some unknown reason, re-installation failed… lost all installed programs after reboot… had to do a fresh installation again… Kernal is still 5.0.0.15, it is the latest in update now, probably i have to find 5.1.15 somewhere else if I need it.
Anyway, wifi seems ok at home now, will further test it today’s afternoon at the very same starbucks where wifi constantly disconnected.
thanks for your advice.
Weird and sad.
I hope that your WIfi works great now
Anyway, if the bug persists, try to reset the bios. Once my laptop became super slow and I didin’t know why. Then I reseted the bios and the speed backed to its normal.
After some time, I found an answer for it: I accidentally pressed FN + F2, which limits the CPU to the half of the potency. Reseting the bios backed it to the normal, but I could solve it just by pressing FN + F2 again (If I knew this haha)
since windows 10 has no such problem, it is safe to assume that the wifi adaptor is working properly.
I reset bios and re-installed budgie once more (messed it up with autoremove before), need to test it further to ensure the problem has been resolved or not…
thanks for your advise!
…is supported by linux kernel since 4.2 ( by iwlwifi module Linux* Support for Intel® Wireless Adapters )
You should check if linux-firmware package is installed on your system, it’s where to find iwlwifi-7265 ( = Intel® Dual Band Wireless-AC 3165, same firmware as the 7265 ).
thanks for your reply.
I checked out this intel wireless driver for linux before but I didn’t know how to install it, i am new to linux.
many example said extract the content to lib/firmware and then work on it… well… i was stuck…
anyway, I reinstalled everything and my budgie is back to normal…
i updated kernal last night from 5.0.0.15 to 5.0.0.16, everything seems back o normal now.
I have been using this laptop for over 2 hours in startbucks now.
