Showtime show up then disappears
I just installed 22.04 on my Dell DT, dual boot win10, and cannot get showtime to stick to the desktop. At boot or login it will show briefly and then gone. I have removed it/reboot, added it back, rebooted and still will not stick.
Thanks, pete
Budgie 22.04
Dell Optiplex 790 / 1TB /i5 8GB /Nvidia 710 2gb/ Dell 19" Monitor.
Clean install? Is the Showtime window listed in wmctrl -lG, and if so, what is exactly the line? What is the output of xrandr?
Fixed in git master Jacob Use Idle.add to spawn Showtime Desktop · UbuntuBudgie/budgie-extras@db085b8 · GitHub
Suitable for a SRU
Ah, of course, how can I forget.
And what do I do with that?
run the two commands (e.g. in tilix) and post the results.
I’ve got what looks like the same problem: the clock and weather appear when booting, then they disappear. I’m running on an iMac, late 2013.
My output:
me@computer:~$ wmctrl -lG
0x01a0000c -1 0    0    2560 45   computer budgie-panel
0x02200004 -1 0    2554 2560 163 computer plank
0x03000007 -1 0    0    2560 1440 computer Desktop
0x02a00007  0 -112 -20  1392 1512 computer Tilix: me@computer: ~
the first option for wmctrl is a lower-case L, not upper-case I.
xrandr
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 16384 x 16384
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95*+
   1280x720      59.86
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
Thats a bit over my head. I just removed showtime from budgie settings and installed conky manager with gotham theme. I have used conky for 10 years or so with no problem and I can write my own configs,
This will be fixed in a release next weekend
