So my little wifi icon was normal at first. Then it turned into where it looked like it was trying to show traffic? And then it turned into where it just looked like a blob.
After a little while I noticed a second machine had the same issue. So on mine I removed the system tray applet. I figured if I removed it and then added it back it would be fine.
Well, so far it has looked like a wifi icon since. But I can’t put it back where it was. When I added it back it came with a bunch of additional space on the right side of it? I have checked and it is not separators or spacers in the panel that I can remove.
I tried a few more times removing it and putting it back to no avail. One of the times every time I moved it right it gained a space, lol,
Right now it is camping out over on the right end of the left side where the menu is until I can figure something out. It has continued to look fine like a wifi icon since, no wierd blob or anything.
What would cause this big space to it’s right side?
Is there a way to just reset the panel to default on my machine?
